TwinTurbo.NET: Nissan 300ZX forum - Re: Assembly lube on bearing surfaces and cam shaft/lifters
nonstopna
on February 09, 2020 at 7:02 PM
posted by ZXRider
on February 08, 2020 at 08:08 PM
what about some light assembly lube on the walls?
Starting rebuilt engine guidance
Kvert
19:38:03 02/07/20
From what I understand you disconnect the fuel system (n/m)
ctheobal
21:02:06 02/07/20
To prime oil
BlackholeZ
22:47:03 02/07/20
2nd
vorpalZed
09:28:41 02/08/20
And keep a wrench handy to clang on a jackstand. (n/m)
MixManMash
15:36:08 02/08/20
*rolls eyes... whistles* (n/m)
vorpalZed
22:16:03 02/08/20
lol thats so messed up... i swear I'd grab the nearest
nonstopna
18:51:02 02/09/20
If you're really that concerned, check out this prelube tank
Polishzx
23:17:45 02/07/20
Also the CAS position should be fine. Check if you have any
Polishzx
23:26:48 02/07/20
Yeah those are nice.
BlackholeZ
01:28:09 02/08/20
I've fired up many new longblocks..
Stanky (BC)
11:02:26 02/08/20
I did the same, no issues.
platinumist
13:38:40 02/08/20
This. (n/m)
MixManMash
15:33:26 02/08/20
Agreed. I do the same. (n/m)
Woody75 (Denver)
12:50:17 02/10/20
i used Guapo's guide in the faq section. but
slayer fan
13:23:16 02/08/20
ZXRider
20:08:56 02/08/20
Re: Assembly lube on bearing surfaces and cam shaft/lifters -
nonstopna
19:02:48 02/09/20
I was told any assembly lube on the cylinder walls
ZXRider
20:22:40 02/09/20
^Correct
-Grimm-
13:12:31 02/10/20
Interesting. Why ATF instead of engine oil?
ZXoltan
14:59:44 02/12/20
(From what I was told) ATF acts as a light lubricant for...
-Grimm-
13:06:56 02/13/20
I did have a problem building oil pressure
Rocket man
18:01:09 02/09/20
This is what I have done for the Z as well
-Grimm-
13:15:06 02/10/20
Re: Starting rebuilt engine guidance
Kvert
07:02:31 02/17/20
Kvert
07:47:02 02/17/20
